laknox
Jul 08, 2019Nomad
Gjac wrote:laknox wrote:Thanks Lyle, I had looked at the Durango 250 RES on their web site and also found the 1500 245RL, more FW but heavier that is why I zero in on the 231RK. The Durangos claim to be 1/2 ton tow able I would just feel safer towing with the lighter 231FK. I see Ford has a HD 150 5.0L Ti-VCT V8 GVWR 7850 lbs, payload 2,890 lbs, in a super cab and a 3.5L EcoBoost® V6 GVWR 7850 lbs, and a payload of 2870 lbs. I guess if I add 1000lbs for people and stuff that would bring the actual weight close to 7100 lbs. Would the hitch weight increase to 1000 lbs or there abouts? Would this be a safe combination to tow?Gjac wrote:
I have owned a 33ft Class A MH since 2004 and am familiar with Class A's. I have been looking for a smaller RV's such as TC's, 24ft Class C's and now 25-28ft 5th wheels. I know little about these RV's other than from searching on the internet. What started the search for small 5th wheels is I did not want to drive a big DRW truck as a second vehicle that I would need for a TC with some room, storage and FW for an RV that would be used for maybe 3 months of the year max. The short 5 wheel looked like a good compromise. So what I have found was a KZ Sportmen 231RK 25ft, UVW 6100lbs, DHW 840 lbs,FW 37 gals and pass tru storage. Second option was a Winnebago Mico Minnie240 5RL 27ft,UVW 5740lbs,DHW 1140lbs,FW 31gals and pass tru storage. Looked at the Escape 5.0 but it had no slide. Do any of you own or know something about these two 5th wheels? Or can recommend other 5th wheels of similar size and specs?
Since you're already looking at one KZ, I'd also recommend that you look at the Durango Half-Ton and Durango (NOT Gold) lines for more options. Decent quality, if my '17 model is any indication, and their customer service is excellent, too. The Half-Ton series is the follow-on to their previous D1500 series, though I'm not a fan of all the changes. If you find an older 1500 series, take a look at them.
There's a good, relatively active, user forum for KZ. www.kzfamilyforum.com. As here, people there are always ready to answer questions. Several members there also post here.
Lyle
The only way you can estimate the pin wt of a FW is to figure that the pin's going to be 20-25% of the GVW, so a 10k GVW FW's pin could vary from 2k to 2.5k. Unless you can find someone who has the exact model you are looking at and can weigh it, this is all you can really do.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
