Bobcat698's avatar
Bobcat698
Shorter pin box, dimension recommendations?
Picked up a new to us 2007 Kz Sportsmen 3551lx.
I'm new to camping in general so there's a bit of a learning curve.
As you can see the camper is a bit low on my stock height Ram. I'm thinking I'll have to do a subframe lift this fall in the off season as it tends to drag the rear in certain situations. I should be able to go down about two inches on the hitch and get to the magic 6 inch number people seem to recommend.
My other issue- the pin box on this trailer is extended, a lot. It tows just fine but I'd rather have it further forward to A- get more weight on the front of the truck, and B. Stop scuffing my tonneau cover rails
I think I'm going to go with a Moryde, they seem to have a good following and aren't priced too high. The camper pulls fine but if I'm going to replace the box I might as well upgrade at the same time.
They have two options, a short pin box which would move the trailer forward 21 inches from its current place, or one that'll move it 9 inches, they call it medium. The short box would only allow around 7 inches of clearance between the bumper and the front of the camper.. Not sure if that's too close.
Any thoughts?
Thanks in advance!
  • shadows4 wrote:
    First thing you need to do is resize the picture. It's way to big.
    Working on it thanks
  • First thing you need to do is resize the picture. It's way to big.
