cutty72's avatar
cutty72
Shorter toy haulers
Ok, currently I have a 04 Jayco Talon 36Z.
It's a 39' 5th wheel TH, with a 12' garage and a super slide.
We really love the layout and space. I HATE towing it in the wind.
I would love to find a rig with a shorter overall height, I think even if I could get down to 10' height would help a lot.
Requirements:
-5th wheel / goose neck
-Pass through from LQ to garage area
-Slide out
-min 12' garage
-walled off garage area
-insulated and heated/AC garage area
-40' or less total length.
I have looked at Millennium trailers, but the problem I have is the longest LQ with a passthrough is 14'. Slides are minimal, and it still ends up being a 38' trailer.
Are there other options out there?
We use our garage as a second room for visitors/friends, or the dogs. Also for storage of the toys in bad weather.
Any input is appreciated. Not in any rush, just looking around for what the "next rig" will be.
  • There are lighter weight lower profile front bed 5ers out there primarily labeled as 1/2 ton towable but they are not THs.
    Lowering your current trailer will put you nose high while towing which is no better.
    So yes given your current set of "requirements" does equate to a unicorn. Either need to reconsider your requirements or upgrade to a more capable TV.
  • The trailer is not the problem, the under sized truck is. The length and weight will cause more issues than a couple feet of height will. You're going to have the same problem with a new trailer unless it's much shorter and lighter or you match it with a bigger more capable truck.
  • Dually's suck, except towing in a parking lot...:W
  • Have you looked at living quarters horse trailers?
    They sit much lower and have a lower overall height.
    Remove the stall dividers and you have a garage.
  • TV is a 01 F250 powerstroke. I understand that even my current is over the manufacturer ratings. Upgrades in suspension, and brakes have taken care of that issue.
    Going "much smaller" would equate to going to a TT, which I refuse to do.
    I've thought about a dually, but averaging about 15k a year, and only about 4k is towing, that's a lot of wear and tear, plus an extra couple tires wearing out, for nothing.
    Plus, duallys suck in the snow, and it is also my primary hunting rig.
    Not to mention that it would no longer fit in my garage...
    I just don't understand it. Looking at a 5er TH, the height is because the entire trailer is above the wheel wells and to give the full stand up front bed area.
    I don't care about standing in the front. Wheel wells take a minimal amount of room. Drop the trailer down 1-2', and gain 1-2 mpg. The economy will pay for itself!
    May just end up with a Millennium or similar, get a 16'+ garage, even though I don't need it, just to lower my total height.
    Apparently I desire the equivalent of a unicorn. :/
  • Your not going to find a 5er at that height. Only a bumper pull will get you that low.
    What is your TV? Have you considered upgrading the TV to match? Dually possibly?
    Given your requirements I don't think your going to get into something that's much smaller than what you already have
