jffnkrn
Jun 19, 2016Explorer
like said earlier, make sure the tank does not have a blockage, check the pee trap, use a zip it for clogged hair etc. I am sure the black tank is not tied into the grey only accept the drain pipe with the valves. also double check the vent on the roof to insure no blockage there. Whatever you do be careful not to damage pipes with wire or metal that is not designed for drain cleaning. Of course be careful of any chemicals you use for unclogging as you shouldn't mix chemicals. Just take your time, if you have to get a hold of a professional so you don't get hurt or sick. Good Luck & Be Safe ! ! !
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
