1st Response Medic wrote:
I have an FS2500 WW that seems to be bowing out around the area of the slides (for the bunks) closest to the front of trailer, are located. When the bunks are lowered, the lower bunk barely sits on the tabs located at lower end of slides. Does anyone have a similar problem and if so what is the fix.
WW had a big problem With the support riggers not being strong enuff to hold the weight of the wall on the trailers with smooth sides. If this is the problem you are having the sides have to be lifted back up to where they belong and extra riggers need to be added.
