glazier
Feb 17, 2014Explorer II
Once you loosen the two bolts on the wedge, back into it as normal allowing your jaw to close. After the jaw locks, chock the rear of your trailer tires and put your truck in reverse. This will force the loose wedge as far back as it could ever go while being hooked up. After forcing the loose wedge, unhook as normal then tighten the 2 bolts to the proper torque. This should have you in good shape for hooking up the next time. If you attempt to install the wedge by hitting it with a hammer while it's in the hitch, you may make it to tight to rehook. As mentioned you will get some movement at the wedge area of your hitch funnel, this is normal. Without the slight movement at the funnel area, you will have a time hooking, and unhooking.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
