kaydeejay
Jul 25, 2014Explorer
afishinado wrote:Careful with the Sidewinder, it puts a lot more upward torque on the pin box than it was probably designed to take. (Think about it - you are moving the support point a couple of feet forward of the current pin, so it you have a 2000# pin weight you are subjecting your pin box to 4000lb/ft of torque)
Thought I would probably be okay with my setup, I had read of a ton of people with sliders that never used them. First trip out, dents on both sides of the cab. Now having parked in a few spots, I need something to make the turning better, no question about it, and it'll be worth the $1000 to get there. Some spots are flat out impossible to get into when you can only turn like 45 degrees...
So;
1. With the pivot now back almost to the bumper, am I going to lose any of the stability I gained by having a 5er?
2. Any more difficult to hook up? as in back under.
Anything else? Any comments?
You might want to check with your trailer manufacturer to make sure the frame can handle the extra twisting force.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
