mfoster711
Jul 26, 2014Explorer II
N-Trouble wrote:I think you (and others) are forgetting that most new 5th wheels already have extended king pins. If you are replacing an extended king pin with the Sidewinder, which is the same length, then there is no difference and no additional forces applied.
You don't have to use one to tell it WILL apply additional forces at the kingpin. Anytime you increase the length of a lever arm additional forces are going to be applied at the pivot point(kingpin).
To clarify, here is a short king pin:
And here is a standard extended king pin found on most new 5th wheels:
If you replace the short king pin with a Sidewinder, or any other extended king pin, then you are applying additional forces to the frame. But, I think 95% of 5th wheels made in the past 5 years already have an extended king pin so most people are fine with the Sidewinder.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
