GPG52_
Jul 26, 2014Explorer II
I have had a Reese Sidewinder with my KZ 30ft 1500 5th wheel and Dodge Mega Cab short box. It worked great and I would recommend for that combo.
The dealer had originally installed a slider but we had problems on the first time backing into our drive. With the slide activated the pin box would gouged our tailgate in a tight turn.
Solution Reese Sidewinder.
Hooking up was an issue as one member mentioned...you had to be
DEAD ON in order to make sure the blocks lined up....
solution dealer installed a Husky 16K-W. Its articulated features solved the hook up problem.
We now pull a 37ft Cougar RES with the Husky 16K-W and find hooking up to be a breeze. The 3 way articulation takes all of the guess work out of hooking up.
PS: we also upgraded our TV to an 8' box. World of a difference.
Regards, GPG
Regards, GPG
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
