n0arp
Jul 11, 2019Explorer
Endricken wrote:
Hmm,
Are Gooseneck Trailer frame failures anymore common than with standard Fifth Wheel Hitches????
I know personally of at least 2 fellow RVers whose front frames failed with normal Fifth Wheel Hitches, one was the RV Dreamers.
Yes its a Lever, but what does it take to MOVE it and cause damage?
Obviously, generally speaking the forces don't normally exceed the strength/rigidity of the components or nobody would have / sell /continue to use a Gooseneck adapter.
My Front Frame broke after hitting a Horrible pothole, that shutdown the Truck CD player and temporarily disabled the Transmission while using the Goosebox. So the Front frame Pinbox assembly was rebuilt with heaver steel and better welds and I reverted to the Star Performance Glider Gooseneck adapter. No problems since.
The GOOSEBOX was a PITA before it failed. Had to re-air the airbag after almost every tow and they want you to grease the adapter EVERY tow.
The GOOSEBOX was bent sometime after the failure before the frame collapsed.
It was LESS than a year old but REESE WOULD NOT Replace it.
Stay away from it.
You've been posting this all over the Internet on every single thread about the Goosebox for the past couple years. This is an anecdote, not of statistical significance.
About Fifth Wheel Group
