n0arp's avatar
n0arp
Sidewinder vs Goosebox vs BD3+1621
We recently brought home a long bed DRW, and moved our Curt A16 into it, keeping the Sidewinder Airborne pinbox that we have on our fifth wheel.
Since we now have a long bed truck, I'm reconsidering our options. I see a few pros/cons with each of the options I'm considering and I'll list them below - but would like some outside opinions on the matter before I decide to make a purchase.
I've previously owned Pullrite Superglide, TrailerSaver BD3, and B&W Patriot hitches. The B&W is still sitting in the garage - despite the huge following it has, I'm not a fan of the latching mechanism on it and don't think the ride that impressive. The Curt rides just as well and I prefer the way it hooks up and disconnects, and the custom wedge for the Sidewinder fits tighter without causing issues (I also have the custom wedge for the Patriot). The BD3 may have soured my impression of any fixed hitch, and I'm considering another BD3 or TS3 as well.
Curt A16 + Reese Sidewinder Airborne
Pros:
  • Already own it, no purchase necessary
  • Tighter turns and closer tracking during turns
  • Since the pinbox doesn't move, you can pack stuff around the hitch when towing
Cons:
  • Noisy
  • Loses air quickly, at least compared to the BD3...
  • High maintenance - have to check torque every outing, lube often, drop and clean/inspect "seasonally"
Goosebox
Pros:
  • Clean bed
  • Ride may be an improvement over the Sidewinder
  • Quiet
  • Low maintenance
  • Doesn't require an external kingpin lock (padlock tabs, I believe, on the second gen)
Cons:
  • Requires ~$1200 purchase
  • Less maneuverable than Sidewinder
  • Might require frequent air fills and greasing
  • Requires quite a bit of space around the pinbox for movement in the bed of the truck - is it possible to store, say, firewood behind the connection when towing?
Other: I don't think hookup will be an issue because of the cargo cam on my Ram.
Trailer Saver BD3 or TS3 + Lippert 1621
Pros:
  • Probably the best riding hitch on the market
  • Low maintenance
  • Really like the latching and jaw mechanism
Cons:
  • Requires ~$3K (new) or $1K (used) purchase
  • Heavy and takes up room in the bed
If I end up changing hitches, I'll list the the other hitch stuff for sale and make some or all of my money back on the new setup.
I'm sort of leaning towards the 2nd gen Goosebox, #94716.
  • No Goose Box. It is glorified goose neck adapter.
    Id go for the Trailer Saver, no questions asked.
    Ken
  • I ended up ordering the 2nd Gen 20K Goosebox (Reese part #94720) and the Curt #60618 GN kit for the Ram puck system. Looking forward to getting them installed and listing the Sidewinder, Curt A16, and B&W Patriot 16K on Craigslist.
    Even though we won't exceed 16K, it's likely we're going to exceed the 3200lb pin on the 16K model.
  • I have to have a Sidewinder in my RAM because I have a rambox bed. That means a B&W Companion hitch for me. I have tried them all, and IMHO, B&W makes the best hitch money can buy in terms of quality and security.
    That said, if I were to have a longbed truck, I would buy a Goosebox hands down. Especially the 2nd generation version that has an integrated lock on it to prevent tampering.
    I have a B&W turnoverball installed on my truck, in addition to the factory 4 corner "pucks" I had to install myself in the rambox bed because they don't offer tow prep from the factory on a rambox. I like the turnoverball for the convenience of stowing it, but I would also look long and hard at the gooseneck ball kit that B&W makes for factory tow prep. It includes a really nice case, and adapters that allow you to use the rear two puck locations to hook your gooseneck safety chains to.
