buckarooman
Aug 02, 2016Explorer
wvcampers wrote:
The vent under the sink will work as long as the drain is not under pressure. You could try filling the sink until it won't drain. then carefully loosen the auto vent or use a screwdriver to release the seal and see if the sink will drain and if it is sucking air or discharging air. If I am right about the pipe being in the tank too far it will be discharging air because there will be pressure on the tank.
There's definitely pressure that's how I I get it to drain normally, if you unscrew it it let's a big burp of air out. With that said how do fix that? Drop the tank and cut the pipe? Pull up on the pipe?
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
