Cummins12V98
Dec 22, 2020Explorer III
TenOC wrote:Cummins12V98 wrote:
To reduce movement make some nice 3/4" plywood boxes as I made. The shorter the ram extends the more stable it is 24k setting on the 6 boxes.
Note tires not touching the ground.
Cummins12V98 How do you adjust the six-point system so that it "automatically" raises the RV past the 1st level point to take the weight off of the tires? Or do you do this manually?
I use the manual mode. Hit arrow up symbol then press enter to start manual mode.
About Fifth Wheel Group
