We are in the process of buying a 2018 Montana 12k dry with 4k carry. should the 16k hitch be good or the next size up better. Any feedback on the size of hitch for this 5th wheel?
Installing the puck system and using the Companion slider would be a great set up. They are expensive, and heavy, as is any quality slider! I'm not the weight police by any means, but you will want to stay aware of your RAWR/tire max rating. That hitch is about 300 lbs, and loaded to camp FW pin could be 3,000+
