DogTrainer's avatar
DogTrainer
Skylight Leaking
Noticed when I hooked the 5th wheel up there was dried dirty water spot in shower. dollars sized and when I looked up there was same dirty spots on lower metal rim inside trim piece of skylight.
I got on the roof and dicor is great, but skylight has small hairline cracks in corners of clear part.
Question is has anyone else been through this and if so can i treat the
cracks or is this a replace the skylight type deal?
  • I used a narrow strip of Eternabond to patch a crack in my skylight.
    I stop drilled the crack before applying the E/bond. Later, I coated the skylight with rubber roof coating.
    But, if the corners are cracking, it may be best to replace the light.
