Michelle_S
Apr 04, 2022Explorer III
When you have multi hydraulic slides controlled a single switch, generally the lightest and usually smallest will move first then followed by the next lightest with the heaviest last. And they will generally follow the same retracting.
If you have shut-off valves for the individual slides you can close the ones you don't want to move. But other than that your system is operating exactly as designed and just like every other RV with multi Hydraulic slides controlled by a single switch.
About Fifth Wheel Group
