CA_Traveler
Apr 05, 2022Explorer III
Only 1 pump is required along with valves, wiring, switches to control each slide. A control board or different switches are required to ensure the owner can only move one slide at a time. Additional weight is small, cost not so much.
For me it's not the time to deploy the slides but the parking situations where all slide deployment is not desired/possible. Apparently some mfgs have an answer with outside manual valves. Like a rest area or street parking at a house, etc. We don't necessarily deploy all slides for 1 night stops. Slide deployment can restrict storage access as another consideration.
My pump and valves are centrally located, 2 slides with 2 rams each means 8 hoses, definitely more expensive. Remote valves would be another option with less hose but individual mounting so not obvious that option is less cost.
valhalla360 wrote:time2roll wrote:
The ultimate solution seems to be adding two more pumps, two more switches and new hoses as needed.
Just money, right?
Not so much a really dumb design but actually a lower cost option.
And since we primarily shop by price....
Not just lower cost but simpler with fewer things to break and likely less weight which is often a consideration.
Since most people don't fret over the extra 10-15 seconds to open all the slides, it's actually a smart design.
About Fifth Wheel Group
