johndeerefarmer
Apr 20, 2022Explorer III
Cptnvideo wrote:dougrainer wrote:
This design(usually Hydraulic slides, never seen any other) has been around for years. All 3 slides are incorporated into the same hydraulic lines and the system extends and puts more pressure to the next slide after the 1st slide has almost reached full extension. I guess I don't really see the problem. It should take less than 2 minutes to get all slides out. The BIG problem is when you just want that one slide for the kitchen to be the only one going out, without the others. Is this system Hydraulic? Doug
I believe it is, Doug. You are correct about the time frame when you are opening all slides.
We moved a couple days ago and after pulling out onto a street, I discovered that I left my phone on a charger at the rear of the 5th. We pulled over and I had to move the 2 street slides out before the slide blocking the entire rear area could be moved out. That slide should be the first out since it is curb side AND blocks access to the entire rear of the 5th.
https://www.youtube.com/watch?v=Qf162nHUPbE
About Fifth Wheel Group
