Dry_Desert_Heat's avatar
Apr 14, 2014
Slide hesitates, sometimes stops
We tow a 2003 Alpenlite Augusta with a flat floor living room slide. This slide extends fine, but has problems retracting in the first 6 inches or so as the slide has to raise. After that, it moves in just fine. We travel 3 months in the summer from Phoenix and make a lot of overnight stops during each trip, so the slide has gotten a lot of use. Had the slide checked by a local shop and lubricated, installed 4 new batteries (first diagnosis was weak batteries) but the slide is still slow on starting when it is warm outside, sometimes stopping entirely when it's cold. Can extend the slide immediately after it stops and try again to close it, so apparently there are no electrical circuit breaker problems. The shop suggested a new slide motor, but admitted that they had seen cases where this change did not help. There are no mud or other buildups on the wiper seals. Could the problem be stiffened wiper seals (due to age and heat) that require much more force by the motor to retract the slide? I haven't tried waxing the slide to make it more slippery for the seals to move over the surface. Your thoughts?
  • With the side fully extended lift up carpet edge and inspect 'rollers' .
    Should be right at edge of slide out. Slide out raises up/slides over rollers as it is retracting.
  • I would place a volt meter on the motor terminals while attempting to slide in. If the voltage reading goes below approximately 8 Volts then the problem is electrical.
