blantonmr wrote:
Hey guys, my 5th wheel main slide out floor rotted due to bad trim and window leak. It was actually bad when I bought it but am trying to replace floor now. I'm going back with plywood instead of OSB but needed to know what to use to glue my floor back down. It has a 3/16" plywood bottom and 1/4" plywood top floor with 3/4" Styrofoam in between. What I scraped off looked like liquid nails but not for sure. The floor frame is aluminum so it needs to stick to it and also the Styrofoam.
Thanks so much,
Mike
To glue back to the aluminum frame I would use Leach's F 26, and to glue the styrofoam to the plywood and the plywood to the Styrofoam I would use Leach's F 13 as it will stick to it and not harm it.
