Miles_Away
Jan 07, 2015Explorer
We use them on our super slide when staying longer than just over night. Don't let all the scary stories frighten you away. The instances where they MAY have caused damage is almost too small to quantify. Most naysayers point to the loss or air in your tires. Most tire failures occur on the road, not while parked, and what are the chances of both tires going flat at the same time while parked? So if using them makes you feel all warm & fuzzy, and if the small amount of labor involved in setting them up is no issue, then go for it. Keep in mind that they are just for extra support, do not crank them up like a jack.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
