PBSAMPLE's avatar
PBSAMPLE
Slide-out problem
We have a 2010 Wildcat 25RL(bought new). No problems until now.
The slides don't start to come in when I push the in switch. Push
the switch several times and then the rooms come in. Never a
problem getting slides to go out.Changed the slide-out wall switch
still have same problem.Has anyone else had this problem, if so,
what did you do to fix it. Would appreciate any suggestions.
Thanks,
Paul
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
    Thanks,
    Paul
    PBSAMPLE,
    Please accept our apologies for this inconvenience. If this is unresolved, please contact Nesa Wilson in our service department by visiting this personalized link: http://www.forestriverinc.com/DirectServiceContact.aspx?ID=636757951334126990.
    In order to resolve your concerns as quickly as possible, please use this link to outline your concerns and Nesa Wilson will respond within 24 hours.
    Thank you, Forest River
    What??? An actual manufacturer responded to this post?
    Hey, even Emperor Marcus hizownself posted here on occasion, back in the day. :B
    Lyle
    Thanks,
    Paul
    PBSAMPLE,
    Thanks,
    Paul
    NOTE: Did you see the "Announcement : ??READ BEFORE POSTING HERE??" located at the top of this forum?
    Check the battery(ies). Bad batteries are often the cause of slide and jack issues. Also, might want to check the output of your power converter to the battery(ies). If that's weak, then you get "weak battery" issues, even though they might still be OK.
    Lyle
    Thanks,
    Paul
    PBSAMPLE,
