pattirv's avatar
pattirv
Slide out wiper seal advice needed
Hello
My name is Patti and I am new to the forums.
I have a 2012 Keystone Fuzion toyhauler. As I took a walk around the unit yesterday I noticed that the side seal on the bedroom slide was ripped and has exposed the internal part of the slide. I have temporarily secured the rubber seal until I can get this repaired.
My question to you is how do I fix this? Can anyone suggest where to get the parts and some good information on replacing the seal?
Thank you for your help!
Patti
  • Not sure WD-40 would be the best thing to use on rubber. Silicone would of been better and wouldn't hasten deterioration of the new seal.
  • Sorry it didn't pull out of a groove it pressed onto a male trim. It had a spring loaded V that pushed on the male trim piece. If you go to pellandent.com and look at the trim pieces Model 19-G8120 and model 19-G8138A they are similar to the wiper I replaced. They press on to the male trim firmly by hand. This is where I purchased what I needed.
  • I replaced the top wiper on a 2004 Keystone Outback 5th we had. It was a very simple job, it pulled out of the groove it fit in and the new went right back in. I lubed the groove and wiper with WD 40 to ease the installation. I made a sketch by tracing the end of the old one on a sheet of paper, took measurements and got on the internet and bought a stock length then cut it to the needed length +1". The side wiper was the same as the roof (top) wiper. I'll do some looking and see if I can find the internet address of where I purchased it.
  • My seal on my previous Travel trailer did the same thing. It has to do with the cheap rubber used and the Florida sun. It did this even though I religiously lubricated it with slide out seal lubricant. I was doing just that when it tore apart wiping it down previous to application right before selling it. I called a mobile RV guy who ordered the part and installed it. Found the guy on Craigslist.
  • Your local rv store should have a replacement, just remove the old one and take it to the store.
