outback_06's avatar
outback_06
Slide out
I have 2017 kHz Durango gold fifth wheel. My dining slide when pulling in or putting it out the trailer side is raising higher than normal and is a little tippy. When fully extended it is solid and looks good. The same when pulled back in.
  • Assuming that you have a Lippert framed unit. Look underneath, Adjustments can be made & are easy to do. You need to have a look & figure out what has what effect on the slide. If all is good when it is out & all is good when it is in I would not sweat it much. Just be sure that nothing has come loose or a nut has not gone missing.
