TDiddy51's avatar
TDiddy51
Slide topper tension too loose
Hi, one of my slide toppers seems to allow the vinyl fabric to be so loose that a significant amount of water collects when it rains. I kmow that you can't expect no water accumulation, but this is extreme. Is there a way to adjust the tension on the roller so that it doesn't sag so much. Hope to hear some positive feedback. Thanks in advance.
BTW, it's a 12' wide slide-out.
  • It may not be something you would want to tackle unless you know how to do it. Sort of like the springs on your garage door.
  • My service dept. tightened it up about 4 turns and it is much better. This is on the Dometic slide topper. My two Carefree toppers allow the water to drain and never sag. Buckeye Chuck, I think they're BS'ing you.
