linusandsushi's avatar
Apr 23, 2016
Slide Width for the 2016 Cougar 336BHS?
Hi everyone - I feel a little ridiculous for not being able to track this down myself but cannot find it on Keystone's site or on my local dealers site.
We are looking at the 2016 Cougar 336BHS, and the specs list the trailer width of 8 feet - but for the life of me I cannot find the width with the slide out.
Anywhere I can find this out??
  • cant_remember_ID wrote:
    I measured the inside seal to where it contacts the slide as I don't really have room to extend the slides in the storage spot. The main slide will extend out 36 inches and the kitchen will slide out 22.5 inches. The bunk slide goes out a little further, maybe an inch or two.
    I hope that helps.
    It does, thanks so much! :)
  • I measured the inside seal to where it contacts the slide as I don't really have room to extend the slides in the storage spot. The main slide will extend out 36 inches and the kitchen will slide out 22.5 inches. The bunk slide goes out a little further, maybe an inch or two.
    I hope that helps.
    I have one, I'm planning on stopping by the storage lot today anyway, I'll Get some measurements for you. The bunk slide comes out just a little further than the kitchen slide, but probably only and inch or two. The main slide is wider. When closed, both slides in the main area come right up to the center island.
    Thank you so much, that would be awesome!
  • I have one, I'm planning on stopping by the storage lot today anyway, I'll Get some measurements for you. The bunk slide comes out just a little further than the kitchen slide, but probably only and inch or two. The main slide is wider. When closed, both slides in the main area come right up to the center island.
  • Main slide outs are generally 36 to 44 inches. Always under 48 inches. An opposing slide out has to be less since it is difficult to fit two full width slide outs in an 8 ft wide trailer. Mine is around 24 inches, definitely less that the space required to open the exterior door.
    Most kitchen/entertainment and wardrobe slide outs are around 24 inches. Looking at the 336BHS, the rear bunk slide out is probably 30 inches and the main slide in the 36 to 44 inch range.
  • Try calling Keystone directly on Monday...*closed today
    Phone (574) 535-2100
