laknox
Jul 23, 2018Nomad
ScottG wrote:
I've used dry lube for years but I recently noticed that after I run the slide in and out a couple of times, the lube is gone and the teeth start rusting.
I'm going to try something a little more clingy, like chain lube. I don't care if it attracts dust - it's still better than metal on metal gear gnash.
If your getting a lot of squeal when the slides are moving, you might look and see if your system has some rubber rollers that the floor runs on. I found that all the horrendous screeching was coming from these wheels.
They're mounted on a simple bolt so I supported the slide with a jack, removed the bolts and greased them.
Slide has never run so quiet!
We used to put a squirt of graphite powder in the seed boxes of our planter with each refill and the seed plates would still rust when it was humid. Just because there's rust, doesn't mean that there's no lube. Just sayin'...
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
