Dayle1
Sep 11, 2014Explorer II
Replacement is not difficult. With the slide-out open, remove the aluminum trim strip along the bottom of the slide-out end walls. This holds the side of the runner in place. The bottom of the runner is attached with double sided tape, so use care not to damage the underside of the floor while removing it. Probably best to remove a section at a time. The front part of the runner is removed from inside the trailer. Use a bottle jack and wood blocking to lift the slide-out floor just enough to take pressure off the runner. Clean up the surfaces as needed. Remove part of the protective paper off the double sided tape and slide the new runner into place from inside the trailer. Then from underneath, remove the rest of the paper and push the runner into position. Reattach the trim strip and remove the jack.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 23, 2026
