DRM796's avatar
DRM796
Explorer II
Oct 18, 2014
SLIDEOUT PROBLEM?
Had the camper opened up today to clean for upcoming trip. When I closed it up the slide outs closed but seemed a little different. All 3 are hydrolic and operate from 1 switch. When I close them the bedroom goes first then the small one in the living area and lastly the large one in the living area. The first 2 closed fine. The third got just about closed when it seem to stall then continue to close a couple of times but did close all the way.
I am plugged into 120 volt 30 amp outlet. Fluid level seems fine. Is something about to go wrong? Any ideas what could cause this?
Thanks
  • My slides operate on 12v DC...even if plugged into shore power...make sure your batteries are fully charged. What you are describing sounds like weak batts.
