cummins2014
Oct 21, 2015Explorer
tcamper wrote:
I am growing weary trying to figure out which hitch will work with my 2015 Ram 3500 / 6.5 bed with the Ram Puck System.
My heart is sold on the B&W Companion RVK3600 but figure I need to stay with a slider. However the RVK3600 does allow for 6 inches of rearward permanent adjustment. Is this enough to not need a slider ?????
B&W also makes a slider (RVK3400), but I would not be able to utilize the factory installed puck system.
I also like the ISR Series SuperGlide (model 2900) from PullRite. But would need to buy a new picture frame adapter (model 4439) to make this work in the pucks, but this causes me concern on the hitch being too tall.
I’m just not finding a lot of options for a 6.5ft bed with the Ram Puck System without using the Picture Frame 5th Wheel Hitch Mounting Adapter.
I would sure appreciate some guidance from the Ram guys that have already been down this road.
The picture frame is working just fine with my truck 2014 3500 Megacab. I wanted to use my existing hitch when I bought the Ram. My hitch is the Reese slider. The only height issues is I can't lower the hitch enough to get level , and have adequate bedrail clearance.
The picture frame is not an issue in reality its only about an inch taller then standard bed rails . My issue is the fifth is just not tall enough for these new trucks. Picture frame adapters are not going to cause an issue , you are going to run out of bedrail clearance before anything trying to get your fifth wheel level .
About Fifth Wheel Group
