Me_Again
Oct 21, 2015Explorer III
I put in a Demco Hijacker 6099 picture frame and a manual B&W RVK3270 slider. I found that I could turn pretty shape with the hitch in the tow position, however with the large box in the front of the bed, I would not be able to unlatch the hitch in the tow position. I set the head in the rear bolt holds. The RVK3270 has only 2 positions where as the RVK3600 has 4.
If you are not going to have a box in front of the hitch, then I think a RVK3600 in it's rear most bolt holes will be fine. I could most likely turn about 75 degrees. You will note I have an extended pin box and curved front.
Note, if you have a tail gate on you have to watch for it hitting when hitch is slide back! Chris
About Fifth Wheel Group
