jamieline's avatar
jamieline
slider hitch
How many people that have a slider hitch have used it and how often?
Short bed trucks. I hear trailers are made so you don't need it but just wondering who has used and under what circumstances?
Those that don't have it do you wish you did?
Thsnks
  • Most newer fivers are "cut" in the front so that they won't hit the truck when cutting really sharp. However, you could go a year or two and never have to slide your hitch and then one day you get on some uneven ground.
    If your FW leans a little while jacking it into a tight camp site you could find that you do need a slider.
    Thsnks
    Another vote for a Superglide (Auto-slider)
    My fiver has a straight front and would be 11" into my cab at 60 degrees but for the slider.
    It's still close, but it misses!
    Thsnks
    Short Bed truck.
    Automatic slider - PR SuperGlide.
    Gets used a lot. Tight turns. Had to regularly make a tight loop where I parked my trailer.
    Got to watch it work often - and see how close the trlr got to the TV.
    (cringed the first time I did that - the spotter also)
    Occasional U-turn every now and then.
    Trailer (a 2006) was before the current "don't need a slider" models.
    Those that don't have one, and wish they did - usually know who they are, LOL!..;)
    A friend was workcamping in Alaska. Got there early in the season.
    His camp spot was plowed - but required some tight maneuvering due
    to the snowbanks.
    He had a manual slider - but it was cold and figured he could get it
    done w/o getting out.
    Bad choice. Knocked out the back window. Local auto glass shop/s
    didn't have a replacement (took two weeks).
    Temp plastic for a back window not good in Alaska.
    He wished he had:
    1. Moved his manual slider to the rear position..:S -(or)-
    2. Had an automatic slider (he does now).
    Kinda like the 4X4 folks......
    Better to have it and not need it (4X4) - -
    than to need it and not have it...:W
