Dayle1 wrote:
up2nogood wrote:
Dayle1 wrote:
14 years w/o a slider, then 10 years with a manual slider that I never used (now sitting in my garage), currently 2 years w/o a slider. Now my hitch is again removable in two light weight pieces. Generally, the "need" for a slider can be avoided by a little extra jockeying back and forth.
Your analogy works great until it doesn't, and of course it only takes once. That extra jockeying back, and forth can work, but there sure are better ways. I would recommend an automatic sliding hitch to anyone with a short bed truck especially IF they are starting from scratch . Takes all the jockeying back ,and forth , and the possibility of knocking out a rear window, or denting the cab.
Sorry, but it is not an analogy. Yeah, I started before even manual sliders were an option. But that meant I focused on the task rather than just throwing the truck in reverse. It has worked fine for 26 yrs. Now when I get older I may need the help of a slider or just stop towing completely.
I was simply pointing out why go to all the hassle of jockeying back, and forth to avoid an issue. I'm sure its worked for 26 years for you , but is there some reason not to have a slider to avoid any issues ,or as you do, jockeying back ,and forth .
