Bionic Man wrote:
Dead horse here but it depends on the trailer.
On our first RV I never used it. When we changed to our current trailer with our old short bed truck I needed the slide every time I took it home.
And I agree with those that say if you need a sliding hitch to spend the extra $ and get an auto slider. They are more expensive but not needing to stop, drop landing gear, slide, put gear back up gets to be a pain.
Stop and drop the landing gear to slide the hitch? Why on earth would you do that?
I have a Ram short box with a B&W companion slider. To slide, I get out and unlock the hitch with the handle, apply full brakes to the fiver using the controller to lock them up, and pull ahead slowly. The hitch slides back and locks. I only drop the landing gear when I'm ready to unhook. Backing up with it slid back is actually easier. I can stick it in the same spot in my driveway every time.
I have a modern fifth wheel with the rounded corners and need it to back into my driveway and some camp sites.
So, mindful of the comments of you don't need one, I didn't slide it back the very first time I brought it home - I can tell you that the turning radius on my 2017 truck was more than enough to enable contact with the cab as evidenced by the sound of breaking glass.
Maybe the comments about the Ram having the hitch placement the closest of the three are correct, but decide for yourself.
Also, when considering an auto slider, make sure you can back into it at an angle. The ones I researched required the ability to back straight in.
So if I was only going to pull through spots or had a huge property, maybe I'd never need to slide it. I don't need to slide it when backing into my space at storage.
That's my experience - good luck with your decision.
