donn0128
Oct 05, 2014Explorer II
First you need to rebuild the motor clutch. Then you need to stop over traveling the landing gear.
On the top of each leg there should be a cap. Pop it off and look on the under side. Write down the numbers then call Venture Mfg and talk to them. You can order parts direct from them to rebuild the clutch assy pretty reasonable
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 14, 2026
