b_pilot
Oct 05, 2014Explorer
The clicking is probably from the clutch. One of your legs is probably binding causing the clutch to do what it is supposed to do. I had a similar problem. My left landing gear was going bad and I was occasionally getting the clicking sound. Didn't know what it was until the left landing gear completely jammed and would not move. Repairman found the shear pin sheared and replaced. Replacing the shear pin did not solve the problem. Repairman rebuilt the gears on top of the landing gear, but still didn't fix it. Bottom line is that it was a jammed inner tube causing the problem. Ordered a replacement landing gear from Venture and all is well.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 14, 2026
