My front legs have separate motors. One of the has become very slow under load. It runs at normal speed retracting but slows dramatically as the load on it increases on extension. Any wisdom from t...
I'm leaning more towards an electrical rather than mechanical problem since it runs fine with no weight on it. I know what gear failure sounds like. Been there. Replaced that. I know about bent legs too. They run fine then bind, load or no load.
Maybe get a new motor then tinker with the old. If fixable I'll then have a spare that will probably never be needed.
Since 2009 the legs have been used litteraly hundreds of times so wear inside the motor should not be surprising I guess.
