DownTheAvenue
Sep 29, 2015Explorer
Any chemicals designed to clear drains are very nasty stuff. If a tub is slow, it is hair and soap scum. If it is a sink, it is probably just scum. I piece of wire stuck in the drain usually does the trick. A plunger after inserting the wire helps, too. You can always remove the traps under the sinks, but getting to the trap in the tub may be close to impossible.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
