Lexx
Mar 22, 2018Explorer
One other thing to watch out for with dual pane windows is your payload capacity. Glass is heavy. On some of the less robust trailers adding several hundred pounds of glass may limit what else you can load on the trailer. Always look at the difference between the unladen weight and the gross vehicle weight. That's your payload capacity. When you start installing generators, dual pane windows, water in your tanks, etc, you may quickly run up against the GVW.
About Fifth Wheel Group
