round_a_bout
Mar 26, 2018Explorer
I purchased a heartland cyclone in 2014. It’s 36’ and gvwr of 14000 pounds.
I don’t have a rear bath but ours has only two slides and they are both on the same side so we’ve fit into some tight spots
I’m very happy with the quality. But these things are hand built and need to be inspected once in awhile since they are being towed many miles
I had to check my wiring. I found some loose connectors behind the control panel and I checked all the main cables. I added an inverted and another battery shut off and some fuses and breakers so I checked all connections while working
I found a couple of loose screws and checked the water line connections. I added some silicone to seal the sinks better and replaced one plastic pex fitting on the hot water heater with a brass fitting.
I removed the two bunks in the garage. But we don’t use it for sleeping. Just living space which keeps the mud and bugs out of the main living area.
I’m very happy with the brand. They try their best to use the best supplies available I believe. And I’ve had nothing but good to say about their customer service the one time needed a part within the warranty period.
About Fifth Wheel Group
