2btowed
Feb 25, 2015Explorer
Is your tank covered on the bottom? If so,they must un bolt or cut the the bottom material.If possible make them unbolt so no cuts in plastic.It is hard to tape back esp,if gas was leaking onto it.Make them replace piece if they do cut it ...never be the same,heck its a new rig.Mine leaked after two years right where the gas hose chocked down and fitted onto the pump.Mounting nut became loose and pump swiveled.It still never never smelled in the trailer,only outside the pump station.Be careful !!
About Fifth Wheel Group
