Having ample power to pull steep grades is not the only consideration. You must be able to go down the other side. If you have never pulled a trailer in the mountains you need to think about the condition of your trailer brakes and trailer bearings. You cannot ride the brakes all the way down because they overheat and fade to nothing!! Gasoline engines will help hold you back if you use lower gears. Diesels must have an exhaust brake to do so effectively.
When we go to the Smoky Mts we always come in from the Interstate 40 down to the Sevierville area and stay at Ripplin Waters Campground. I always try to avoid steep grades when possible. I suggest you read all you can on this and other forums before pulling a heavy trailer in the mountains. Interstate highways generally are designed to allow safe travel. We have been on some roads that have caused the brakes on the truck to smoke when we stopped. Mountain driving is not dangerous if you know what you are doing and plan your routes accordingly.
