fallonator22
Sep 22, 2017Explorer
So hotttt
So we have the 2016 sandpiper, it came with 2 ac units, 15000btu. One in the front living area which is over the truck bed, and one in the back master bedroom. We are currently in corpus christi, T...
ksg5000 wrote:
Your goal of having 70 degree inside when it's blazing hot outside may not be realistic - but only get a 10 degree reduction in temperature doesn't sound right either. Have you bothered to measure the temperature coming out of the vent and is it at least 20 degrees cooler than the temp in the rig? Are you using the high fan setting? If not the air conditioner will likely freeze up which will significantly reduce performance.
