fallonator22's avatar
fallonator22
So hotttt
So we have the 2016 sandpiper, it came with 2 ac units, 15000btu. One in the front living area which is over the truck bed, and one in the back master bedroom.
We are currently in corpus christi, TX where it is humid hot hell. the norm temps so far have been 90's. Prior to this when we first got the sandpiper about 3 weeks ago, we had been parked in magnolia, texas, more north and we had a few cool days, so it wasn't as brutal.
Either way - we first got down here and our A/C (i've posted about this before) was not cooling properly after like the 2nd day. We like to keep it at 67/68 when we sleep, and try for 70-72 during the day. What i've noticed is that the AC's in RV's run a little hotter than, an apartment AC, per say.
After the 2nd day in corpus, the air was coming out of the vents in the living area, it was cool air, but the temp in that zone was a constant 83 when set to low to mid 70's. Had the guy come out yesterday and he said he could tell a repair or something had been done to it, and that he had to redirect the intake of the air to inside the RV because it was pointed to pull air from in between the RV roof and some paneling underneath. He said other than that, it is working as it should, has plenty of freon, and should be good. After he left, it still never got down to the temp we wanted it, and overnight it still could not get down to the temp we wanted it. Right now it is set to 69 and it is at 73, which is what it's been all night, but it is also overcast and has been raining all night. Just worries me that when it is hot and dry again that it will struggle.
As far as AC's go for RV's - is this normal? Esp for the bigger AC unit? I mean, if that is normal then I guess leaving all the shades shut so it's darker in here trying to cool it down will just be a norm. Also, would it be worth purchasing a stronger unit for the front living? The back bedroom does fine and we have no issues with that one, but it is also cooling a smaller space.
  • Twomed wrote:
    Shade is the answer...slideout cover awnings, window awnings, double pane windows, sunscreen on big exposed glass. That is what it takes to survive in a box in those condition.
    Temporary fix...tree shaded site. :)
    now that you mention it, our awning was out the first day or so but the wind was making it rattle so we pulled it in. the awning covers the breakfast area which has 4 windows on it in itself. good idea!
  • As far as AC's go for RV's - is this normal? Esp for the bigger AC unit? I mean, if that is normal then I guess leaving all the shades shut so it's darker in here trying to cool it down will just be a norm. Also, would it be worth purchasing a stronger unit for the front living? The back bedroom does fine and we have no issues with that one, but it is also cooling a smaller space.
    Normal for most RV air conditioners is to cool the interior of the coach to about 25 degrees F cooler than ambient.
  • Shade is the answer...slideout cover awnings, window awnings, double pane windows, sunscreen on big exposed glass. That is what it takes to survive in a box in those condition.
  • I find it helps to have those fitted pillow thingy's to put in any roof vents. And do they even make a bigger AC than the 15K?
    Looking forward to seeing what others say.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
