Allworth
Nov 08, 2015Explorer II
Open the slide only about 4 inches so you can see the alignment. Mark the frame where the wall is at the end you are going to move away from so you can keep track of how far it has moved.
Go get it!
I have adjusted mine in the driveway both for position in the opening and to rotate the top front corner (and all the other corners since they are attached, DUH!) down and forward to square the slide up in the frame.
It isn't hard. Just go slowly and try not to overshoot. It is more trouble to move it back some than to do it right the first time.
Go get it!
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
