Colo Native wrote:
This is my dilemma I don't boondock but I do road trips that are days travel time, I only run the microwave for a few minutes and maybe a toaster on this trips or charge a device here and there. I am having a hard time trying to figure a 2000w generator or about 300w of solar. Thanks for your help again.
If you don't boondock, why do you need boondocking power? Just pickup another battery and/or better converter for your existing battery and charge it from your tow, or when you plug in during your trips.
For me solar power just doesn't make sense.
Insolation is a very fickle mistress; weather, geography, season, all variables working against getting any energy from a solar panel. Compare that to a generator. Maybe it's dark, or raining, or I'm simply parked in the shade... not a problem for a generator, pull the cord and dinosaur juice is turned into copious amounts of electricity.
Some may say that fuel will limit the time I can spend boon docking. Well, I guess that is a possibility, only if you treat it with ignorance. In planning long periods of boon docking on my Alaskan adventure, I carried along fifteen gallons of fuel. Both for emergency use in my truck, and for the generator. I also carried fifteen extra gallons of water, in addition to the twenty inside the camper. I ran out of water before I ran out of fuel. Even in remote areas, I found both easy to obtain with a special small plastic card my bank gave me.
Some may say the sound of the generator detracts from the surroundings. This is purely subjective and I can offer little retort. Unless you back-packed in, or perhaps on a pack animal of some sort, the presence of the truck, trailer, motorhome, etc is already detracting from the surroundings. A few hours of generator run-time ever 2-3 days won't be that bad.
Consider this:
Watt for watt, solar panels weight a lot more than a generator and its fuel. Weight should always be considered by the RV'er. Just because said panels are on the roof out of sight does not mean their weight is diminished. Depending on latitude and season (insolation), you're carrying 100s of lbs of dead weight that has no practical application. Solar panels work best during peak sun. This is not my opinion, it is a scientific fact that has studied in great detail. A generator has no such limitation, the negative aspects of its weight can always be offset by its ability to produce energy any time of day, in almost any conditions.
just my fifty-cent opinion here. I too briefly contemplated solar for my RV but after analysis of my travel style, location and budget, I decided to go with a generator.
