Colo Native wrote:
This is my dilemma I don't boondock but I do road trips that are days travel time, I only run the microwave for a few minutes and maybe a toaster on this trips or charge a device here and there. I am having a hard time trying to figure a 2000w generator or about 300w of solar. Thanks for your help again.
You state that your road trips are days long? Certainly, you are not running without stopping for days, when hooked up your TV should be charging your batteries, this would keep them topped off, and run things like the fridge, (on propane). If you stopped a couple of times on the way for lunch/snacks a small solar with investor should handle your needs, nothing big like AC. Also, when on these road trips do you boondocks at Wally World or do you stop at RV parks? Again, if you stopped in RV parks and hooked up to shore power, your batteries should be topped off. I do not see anything that would require you to buy a genset. Someone mentioned an advantage to gensets is space, How many batteries would you need to take up the space of a generator and its fuel?
If you do any boon docking, even on your road trips a Genset would be worth looking into. Just my $0.02 worth, good luck.
