Searching_Ut
Nov 04, 2016Explorer
My only recommendation is to wire the panel so that it bypasses the battery cutoff switch, and make sure the cutoff switch is off when the rv is in storage. A 15 watt panel probably won't keep up with your parasitic losses with the battery connected, depending of course on your particular rig.
About Fifth Wheel Group
