Coach-man
Nov 05, 2016Explorer
I had a similar setup on my class A. As others have noted, bypass your disconnect switch, which should be "off" excluding all parasitic loads while in storage. And number two, make sure your controller will prevent overcharge! Also, from time to time, clean your solar panel, to ensure it is getting all the solar power it was designed for.
About Fifth Wheel Group
