Sam_Spade
Nov 07, 2016Explorer
D.E.Bishop wrote:
We now have the Winnie and it does have the disconnect and I have the some draws but haven't had the inclination to check how much.
It doesn't really matter how much; the battery disconnect switch should eliminate ALL of them.
Your battery tender, whatever kind it is, should be wired to a point at or very near to the battery where it will NOT be disconnected by the switch.
IF....it appears that your batteries are losing charge with the switch in the disconnect position, then either your batteries are going bad or something is mis-wired.
About Fifth Wheel Group
